Val-E Posted April 6, 2017 Posted April 6, 2017 (edited) Hoth Bricks are saying this is going to be a 2017 D2C exclusive and the largest Minecraft set so far. Probably a 2H release. http://www.hothbricks.com/lego-minecraft-teasing-plus-gros-set-de-gamme/ Bricksets have put up the box details and it is a big boy. 58x48x17 cm 5kg ie Death Star size! Edited April 6, 2017 by Val-E 2 Quote
HandyHand Posted April 6, 2017 Posted April 6, 2017 I guess Lego Minecraft sells better than we knew, and good enough for Lego to take the plunge and produce a big expensive Minecraft set! Quote
Val-E Posted April 6, 2017 Author Posted April 6, 2017 15 minutes ago, Haay said: I guess Lego Minecraft sells better than we knew, and good enough for Lego to take the plunge and produce a big expensive Minecraft set! I know the smaller sets do well, already out of Ender Dragons and the Mine did well over the last 2 Christmases. Don´t think The Village is a super seller though and have doubts about these massive Ninjago and Minecraft playsets. Quote
Will 4 Posted May 1, 2017 Posted May 1, 2017 Any clue what the dark green windscreen piece is for? Quote
Will 4 Posted May 1, 2017 Posted May 1, 2017 6 minutes ago, Shewie said: Looks like "famous" Alderaan Set to me. Clearly it is Jeddah city. 2 Quote
Val-E Posted May 8, 2017 Author Posted May 8, 2017 99% sure this will be the early access to VIPs set in June. 1 Quote
TheOrcKing Posted May 8, 2017 Posted May 8, 2017 A charged Creeper and a little bat, neat. There must be many play features to go with the ton of parts. I imagine the beefy instructions to have plenty of inspirational side builds too. Quote
Alpinemaps Posted May 8, 2017 Posted May 8, 2017 Moved the general discussion about the Minecraft theme to this thread: Quote
Dr Jedi Posted May 9, 2017 Posted May 9, 2017 This thing is looking enormous. Too bad I have no interest in this line. Quote
Phil B Posted May 9, 2017 Posted May 9, 2017 Looks like it's easily 2500-3000 pieces. I'm expecting a full Mine on the back, judging from the tracks and the Mine shaft supports on the left. Quote
Val-E Posted May 9, 2017 Author Posted May 9, 2017 Reminder of box stats: Dimensions 58.2 x 48 x 17 cm (22.9 x 18.9 x 6.7 in) Weight 5.09Kg (11.21 lb) Quote
inversion Posted May 9, 2017 Posted May 9, 2017 (edited) I wonder how it looks from behind. It still does not look anything special, just a way oversized simple play set. Edited May 9, 2017 by inversion Quote
Shewie Posted May 9, 2017 Posted May 9, 2017 14 minutes ago, Val-E said: Reminder of box stats: Dimensions 58.2 x 48 x 17 cm (22.9 x 18.9 x 6.7 in) Weight 5.09Kg (11.21 lb) so Assembly Square/Death Star size of the box. Quote
Phil B Posted May 9, 2017 Posted May 9, 2017 29 minutes ago, Val-E said: Reminder of box stats: Dimensions 58.2 x 48 x 17 cm (22.9 x 18.9 x 6.7 in) Weight 5.09Kg (11.21 lb) 13 minutes ago, Shewie said: so Assembly Square/Death Star size of the box. Weight of 10188 (no weight on BL yet for 75159) is 8kg, for 4000 bricks. So 5kg is 5/8 * 4000 = 2500 pieces. Right what I estimated Quote
Shewie Posted May 9, 2017 Posted May 9, 2017 1 minute ago, Phil B said: Weight of 10188 (no weight on BL yet for 75159) is 8kg, for 4000 bricks. So 5kg is 5/8 * 4000 = 2500 pieces. Right what I estimated but the minecraft blocks are tad bigger than usual brick from SW themed sets. That's why it's hard to estimate the amount comparing straight those two Quote
jaisonline Posted May 9, 2017 Posted May 9, 2017 if the set is 10lbs, it should mean a lot of bricks and plates. 1 hour ago, Val-E said: Reminder of box stats: Dimensions 58.2 x 48 x 17 cm (22.9 x 18.9 x 6.7 in) Weight 5.09Kg (11.21 lb) Quote
thedingman5 Posted May 9, 2017 Posted May 9, 2017 Per LEGO's instagram post, the ABS in this thing is 3.36kg Quote
Phil B Posted May 9, 2017 Posted May 9, 2017 That bat is a cool little build - two minifig neck-brackets mounted on a 1x1 brick with studs on 4 sides, sideways. Quote
