labfreak7 Posted December 21, 2016 Posted December 21, 2016 Just got this small 4 lb Bulk lot todayHas about 14 minifigures including most of the quiddich match figuresI do see parts to the quiddich match tooWhat else do you guys see ? There is a separate bag with what looks like hagrids hut but I'm not sure. Quote
0 Guest brickcrazyhouse Posted December 21, 2016 Posted December 21, 2016 5 minutes ago, labfreak7 said: Just got this small 4 lb Bulk lot today Has about 14 minifigures including most of the quiddich match figures I do see parts to the quiddich match too What else do you guys see ? There is a separate bag with what looks like hagrids hut but I'm not sure. was there an image to go with that? Quote
0 Guest brickcrazyhouse Posted December 21, 2016 Posted December 21, 2016 I start with big pieces like the door, and see if any of these sets look like they're in there http://www.bricklink.com/catalogItemIn.asp?P=87601&v=1&in=S&srt=0&srtAsc=A&ov=Y Quote
0 Huskers1236 Posted December 21, 2016 Posted December 21, 2016 For sure I see parts of Slave I, Hagrid's Hut, and Quidditch. Those navy blue parts toward the top are probably a Tri Fighter or something similar. The Trans Green on the left is probably Galaxy Squad, but I'm not as versed in that line as some others. 2 Quote
0 jkris53406 Posted December 22, 2016 Posted December 22, 2016 Definitely parts of 8097 Slave 1. Quote
0 longshot Posted December 22, 2016 Posted December 22, 2016 Definitely the Hut, just put that one together and as others have mentioned Slave 1. Quote
0 Thumper Posted December 22, 2016 Posted December 22, 2016 Judging from the assembly configuration of 2x white rotor blade extensions (with the attached red plate 2x4, 2x2 pm w/pinhole and tlb 1x1 brick round) in the upper right and lower center, looks like you have some of the Galaxy Squad: 70708-1 Hive Crawler 1 Quote
0 Huskers1236 Posted December 22, 2016 Posted December 22, 2016 Those red doors(one looks to have a white panel in it) are probably Ninjago. Putting those with the reddish brown door give you this set: 2504 1 Quote
Question
labfreak7
8 answers to this question
