11 hours ago, keymomachine said:
Would it be possible to add the RRP to the Brickfolio export data? I see it's got piece count and set year but RRP would be handy for me. Thanks for all your hard work, Jeff and Ed!
Will do!
  • Thanks 2
I went through and cleaned up the titles in the LEGO IDEAS sub.  Now each set thread includes the IDEAS number, along with the set number and name.  Also added threads for the IDEAS sets that didn't have a thread already.
  • Like 2
I am no longer seeing Unread Content in this forum (comes up as empty) even though I know there are new posts. Recent Posts does show some content (very little). This is on desktop. On mobile, neither iOS nor Android BP apps show any content in the "All" or "Unread" tabs. Is there an issue?
3 hours ago, KShine said:
I know that there is a system glitch - but regardless, I still miss the days when there were people actively posting.
You know how it works...every late Spring and early Summer, forums take a hit from nice weather and people getting out.  As soon as it gets hot or the Fall comes, people get back inside and back into their routines.
  • Like 1
issues with some of the newer sets:
not in DB:
60230 - People pack - Space Research and Development (a Bionicle set shows up)
40344 - MF Set – Summer Celebration
in DB but does not pull up when attempting to access in my brickfolio
40343 - Spider-Man and the Museum Break-In
  • 4 months later...
1 hour ago, exciter1 said:
Another issue I've noticed, maybe a quick fix, the auto affiliate feature is breaking all of the links people post. The go.brickpicker.com feature.
Thanks, this should be working normally now.
  • Like 2
Hi an aussie here checking out brickpicker after a long break.  Site has changed a bit, no more searching for lego sets that I can see?  Is there a way to get the CAGR anymore?
Regarding the discussion of getting accurate pricing info out of eBay, yes it is not a trivial task.  You would need to be a competant data scientist to provide a workable solution and it would take a long time to develop and train the model(s) needed.  Not sure how much info you get from the eBay API either and whether it would be adequate to predict useful values.  I work in the data team at a business here in aus and work closely with the data science teams, it does take time and specialist skills to get it right.  Small changes to the data feed can lead to poor predictions.  There is likely to be a way to achieve the outcome though if there is enough data available and someone with plenty of patience to work on it...
It would be an interesting project to work on though :)
  • 3 months later...
